The brush hog looks well used (visible weld repairs on the deck) and only stays up 5 or 10 seconds before it returns to earth. There don�t appear to be any visible hydraulic oil leaks, so are we talking seal replacement? Rebuilt pump or actuator? Didn�t see any leaks around the brakes. Are the brakes similar to a car, in that I could go through the system with new linings, rebuilt wheel cylinders & master cylinder? (can you tell I�m treading on new ground?) The owner says he bought a bigger tractor because this 8N doesn't have enough power and bogs down in tall grass (3 or 4 feet) and on other jobs. I have a compression tester, but if this is a tractor is a good deal, I think I would not bother doing a compression test and just plan on doing sleeves, pistons, rings, bearings, valves, etc. this winter (next to my wife, I like old engines!) 8^) Another possibility is buying a dead tractor and doing a total restoration. I might come out with a piece of equipment that I know inside and out for the same or a little more money. I have a 32 Ford sedan and have done a couple of old car �frame off� restorations, so I handle it once I familiarize myself with 8N mechanicals. A couple miles from me is an 8N that has been sitting for a long while (field storage). Would it be realistic to find a dead 8N for about $500 and plan on an engine overhaul, boil out the gas tank and radiator, sandblast and paint, update wiring and charging, and end up with a fresh running tractor for about $3,000 with me doing all the labor? This assumes 8N transmissions and rear ends usually don�t need major R&R. Am I living in a world of make believe? Thanks for your advice, O keepers of the 8N flame. jetson
