trick resistor
tom_ca
02-12-2008 04:25:18
hi i'm looking for info on how to install the trick resitor.
a pic. would be great. should i keep them away from the frame and should they be soldered or can i use but-connectors.
on another topic i have an old 6volt coil that i would like to convert to round can but it has a solid core and i'm not quite sure how to remove the fill without damaging the inside, any help would be great.
tom_ca
02-14-2008 04:35:13
 Re: trick resistor in reply to maplehillfrm,pat, 02-12-2008 04:25:18
thanks for the info guys
as for the resistors should i mount them on frame or just have them hanging from the wires.
once again your info is appreciated
Kevin in MN
02-12-2008 17:32:53
 Re: trick resistor in reply to tom_ca, 02-12-2008 04:25:18
Actuall it that wasn't that hard to clean out, I soaked overnight in gas (outside) and the next day I was able to pry out 90% in one chunk.
JMOR
02-12-2008 17:11:06
 Re: trick resistor in reply to wayne-t, 02-12-2008 04:25:18
Kevin in MN said: (quoted from post at 21:01:14 02/12/08) Here is what you need to build
third party image
third party image
Building isn't the problem..... ..... ..getting the rock hard epoxy out is the problem. Drilling, dremel, chisel, huors of tedious work, not to break the case.
Build it back in minutes.
Kevin in MN
02-12-2008 17:04:55
Well.. the pictures worked in preview?
http://home.comcast.net/~kevinds/Coil2.JPG
http://home.comcast.net/~kevinds/Coil.JPG
Kevin in MN
02-12-2008 17:01:14
third party image
third party image
souNdguy
02-12-2008 05:14:23
P prefer solder connections.. but good crimp on but connectors work fine.. just put a bit of grease ont he wires before crimping to 'seal inthe freshness'.. (wink)
Mount power resistors in places where they cannot damage 'meltable' parts.
If your coil potting is epoxu, you can try torching it out.. good luck.
Soundguy
36 coupe
02-12-2008 14:24:05
 Re: trick resistor in reply to souNdguy, 02-12-2008 05:14:23
Epoxies give off some toxic fumes during the cure.I wouldnt heat cured epoxy.Some people get senitized to epoxies and have to give up using them.
soundguy
02-13-2008 05:05:58
 Re: trick resistor in reply to 36 coupe, 02-12-2008 14:24:05
If he wants it out.. he has very few choices.. I agree.. he shouldn't do this in his living room with his head down over the melting resen inhailing the fumes as they come up.. but between the torch and a chissle.. hell have to get that potting out of there if he wants to gut that can.. His choice.
soundguy
Hobo,NC
02-12-2008 04:43:44
Third Party Image
click on Hobo,,, info is their for the conversion
