Jubilee Hydraulic Repair/Adjustment
dp
06-02-1999 10:42:09
The lift arms on my Jubilee won't lift all the way up- you can manually lift them an additional 4-6 inches. I need them to lift higher so I can dump with my rear scoop. The lift settles in about 5 minutes or so after shutting tractor off, no big deal to me. Also, it won't lift at all in 'constant draft control'. This is, I believe, an early Jubilee but it has a replacement piston type pump with no Hy-Trol knob. I have the I&T FO-19 manual that probably explains the procedure. I'm not quite sure what these symptoms indicate...Could someone please point me in the right direction or give instructions.
EricG.NH
06-02-1999 17:10:24
 Re: Jubilee Hydraulic Repair/Adjustment in reply to dp, 06-02-1999 10:42:09
I can't exactly speak to NAAs, but if it was an 8N, I'd say something in the lift cover is either, broken, worn and/or out of adjustment. It's my understanding that the mechanics of the two lift covers are very similar. Check some of the previous posts for ideas on troubleshooting. Eric
