Aux Transmissions???!@#$%^*
Danti CO
06-02-1999 08:30:38
On the right side of my 1948 8N dash is a big black knob attached to a 1/4" cable running into a hole in the front transmission housing. The slider attached to the knob is rusted in place. The cable attached to the slider has no housing so there is no way to accurately position the knob end with respect to the other end. I would like to rebuild the dash and either fix or get rid of this black knob. My concern is that it is attached to an after market aux trans that could be "deactivated" if I fiddle with it.
I have seen a lot of discussion about auxillary transmissions. Does anyone have any comments or suggestions about this knob and what, if any, type of aux trans could be attached to the end of this cable and how it should work when the cable is moved.
Thanks for all the excellent help on this board.
KCM
06-02-1999 11:19:05
 Re: Aux Transmissions???!@#$%^* in reply to Danti CO, 06-02-1999 08:30:38
Take a look at the attached web site. It shows a picture of what you described and says it is an early Sherman Overdrive. That would mean it has positions for overdrive, neutral, and straight 1:1. I would assume when the cable is pulled all the way out, it would be in overdrive. The cable is probably attached to a lever on the side of the aux. transmission, and the tractor would have to be split at the clutch housing to unhook it or replace it.
You could disconnect it and leave it in 1:1, or remove it and replace it with the stock 8N transfer shaft that was removed when the aux. transmission was installed. If you want to replace the cable, try a place that sells truck hoists or a heavy truck dealer. It looks very much like the cable used to engage the PTO drive on the side of truck transmissions. Good luck.
TC
06-02-1999 11:18:08
I have one on a 2N I rebuilt. Llamas is right, it's useful, with the 3 speed I can't imagine getting by without it. I'm not sure if mine is a Parks or Sherman, but to engage the overdrive I push the knob all the way in. The only way I know to reach it without the cable attached is by splitting the tractor.
llamas
06-02-1999 09:42:45
The knob is a shifter for an auxiliary transmission, I don't have my pitcher book to my hand but from memory it is the Parks brand. I think (Marvin Baumann would know) that they only made a step-up, but I could be wrong.
If you can free up and fix the shifter, you'll appreaciate the added gear ratios it gives since it sounds as though you've been operating in one range only for a long time.
llater,
llamas
Don B
06-02-1999 17:01:34
 Re: Re: Aux Transmissions???!@#$%^* in reply to llamas, 06-02-1999 09:42:45
Contact John Smith via his Web site.He has the same on his 48 8n and has re-worked it.Don
