Long Tie Rod (end) for 2N
Mac McCaleb
06-01-1999 07:07:27
Where can I get the long portion of the right side tie rod end? The one that inserts directly to the steering arm.
Are they still made somewhere by someone other than Ford?
KCM
06-02-1999 11:29:23
 Re: Long Tie Rod (end) for 2N in reply to Mac McCaleb, 06-01-1999 07:07:27
I have the same problem with the rear tie rod end for my '51 8N, though it is shorter than yours. I've been told by the New Holland dealer that you have to replace the middle tube section along with the rear (now real short) tie rod end, since the original longer ends are no longer made. I've seen people cut off the ends of the worn tie rod ends and weld a new short version on.
