6v positive ground
Leonard
05-27-1999 19:29:32
I have an 8n with a 6v positive ground elect ststem the tractor needs rewired so I am thinking about a 12v conversion does the conversion kits come with a wire diagram and a bracket for the alt? and would it be worth the trouble to convert ? I will be gratful for any help
bg
05-28-1999 16:08:55
 Re: 6v positive ground in reply to Leonard , 05-27-1999 19:29:32
Yesterday's Tractors sells the kits complete. (Duh...)Check the link below. There are other places to buy kits, but why not support the board if you're going to buy one anyway?
I don't understand why everybody dislikes the 6 volt system so bad. I've never had enough trouble with mine to warrant the expense of changing.
chris luffey
05-28-1999 02:55:22
Dave,
I also am thinking of converting to 12v. Have you found anywhere that has conversion kits? Not sure what size alternator will be needed. I had a friend convert a massey-ferg. and had to fabricate an alt. bracket himself.
dave
05-28-1999 03:06:25
 Re: Re: 6v positive ground in reply to chris luffey, 05-28-1999 02:55:22
Walts tractors should have it,look under parts section of the board..
Dave
dave
05-27-1999 22:50:12
if your n starts ok and the charging system is working good I wouldnt bother converting..the only time I think I would convert to 12 volt is if my generator crapped out..
Dave
