Order Ford 8N Parts Online
Wiring Diagram...9N and 2N with a 8N Generator
Sean (TX)
12-02-2007 15:43:34
Made a New Wiring Diagram for the 9N and 2N with a A Circuit 8N Generator...GB in MT gets some Credit here...Mine was wired all wrong but it charged...Gary's was wired right and he sent me a diagram..Just my amp guage didnt work... Charged fine...I like a working amp guage...Works now :)
Here it is
third party image
GB in MT.
12-03-2007 05:19:16
 Re: Wiring Diagram...9N and 2N with a 8N Generator in reply to teddy52food, 12-02-2007 15:43:34
Yep, I agree!!!! I just forgot to mention that!!!
Three brush, A circuit system, with V/R !!!
Sheesh!!!..... ALL your things are bigger and better than mine!!!!!third party image
First liar, hasn't got a chance!!!third party image
But..... . it does work, if that's what ya got!
Garythird party image
Sean (TX)
12-03-2007 02:43:30
 Re: Wiring Diagram...9N and 2N with a 8N Generator in reply to Smokeys427, 12-02-2007 15:43:34
Works well with 3 brush A circuit system and V/R to,
GB in MT.
12-02-2007 19:18:23
 Re: Wiring Diagram...9N and 2N with a 8N Generator in reply to Ken Crisman, 12-02-2007 15:43:34
Sean; You got it right! Two brush,6volt, 8N genny, Acircuit sys. and V/R.
Sean (TX)
12-02-2007 16:50:03
 Re: Wiring Diagram...9N and 2N with a 8N Generator in reply to soundguy, 12-02-2007 15:43:34
I think Garys has a right mounted genny to (im sure of it)...All you have going to your magneto is a ground wire...I know cuz that is the only wire going to the magneto on my 67 Mercury outboard...Had to wire that up using the controls from a 80 Mercury outboard..Grounding the magneto kills the engine...Been a while but now that I think about it I think I have the Tachometer hooked up to the same place on the magneto...Outboard is a 4 banger I set the tachometer on 8 cylinder setting and it worked perfect...
Bob From Paradise
12-02-2007 16:30:05
 Re: Wiring Diagram...9N and 2N with a 8N Generator in reply to Sean (TX), 12-02-2007 15:43:34
I looked at this in the listings and thought interesting he is doing what I'm doing with my 2N.
And while its a little different its food for thought.
The only difference is on my tractor there is not s wire to power the coil but a wire that comes off of the magneto to stop the engine a kill wire of sorts.
And that generator from the 8N is that the right side mount or the late 8N left side mount like mine ?
