Order Ford 9N Parts Online
9N hydraulics again
Ken Jansen
05-25-1999 07:13:39
I have disassembled the piston and cylinder for the lift. There are some pretty severe schatches in teh cylinder wall. I can hone them out but it will probably increase the bore by .005 to .010 inches. I have not measured the bore and piston sizes to see if they are in spec. Can oversized pistons and rings be obtained for this unit? if so Where?
G. Lees
05-28-1999 08:28:43
 Re: 9N hydraulics again in reply to Ken Jansen, 05-25-1999 07:13:39
White Post Restorations may be able to sleeve your cylinder back to std size. Ph 540-837-1140 or www.whitepost.c
bg
05-25-1999 15:39:16
The max clearance is .0025" If it's beyond that, you'll have to replace the cylinder. You may be able to fudge with an NAA o-ring/washer piston(about $25). I don't know if anybody has ever tried to bore and sleeve a lift cylinder or not. Probably cheaper to replace the cylinder with a new one or used one within specs.
Ken Jansen
05-26-1999 09:08:45
 Re: Re: 9N hydraulics again in reply to bg, 05-25-1999 15:39:16
The clearance is around .006 now. I will have to find another one. Thanks for the info.
