Order Ford 9N Parts Online
9N Hyd leak
Jim
05-18-1999 15:56:17
I have a leak from the right side (facing the rear)from my 3pt lift. I can't get the large nut off or bolt out to remove the casting and replace the gasket. The 3/8ths comes right out. How can I get this casting loose to replace the gasket?
Is the bolt screwed into something in the housing?
Dell (WA)
05-18-1999 17:49:17
 Re: 9N Hyd leak in reply to Jim, 05-18-1999 15:56:17
Jim..... ..If I understand your problem description correctly, you're talking about the lower link pin (right side). This is a thru pin with a castlated nut and cottor key and is accessable only from "inside" the axle trumpet. Which means you will have to remove your axle and brakes, this really isn't that big a job (compaired to engine rebuild, grin). And while you have everything apart, recommend you replace all axle seals as appropriate, see the I&T FO-4 repair manual for detailed instructions and good pix's.
Now then, the 9N lower link pin is not "tapered" like the 8N pin so watch out if you decide to replace the pin. Often times the mounting hole is "wallered out" (out of round) There have been reports of successful usage of "J&B Weld" after through cleaning. (Check the "archives")
I think the lower link pin it torqued to 150 ft/lbs.
The problem is deciding if it is worth it to you for a little ol' leak. The longer you put it off, the more the hole gets wallered out.
Hope this helps..... Dell
