Order Ford 9N Parts Online
9N Misses and No Power
Gary Perkins
05-17-1999 03:47:06
I just got my 9N running after a winter of no use. When last used last fall, it started running real rough and then quit so I just pushed it in the garage, but it is time to cut grass again. I have a 12V conversion. I have replaced the ignition resistor, coil and rotor, points and condensor, cap and plugs. The carb and fuel lines are clean and I am using 1 turn out on both the idle needle and power jet. It will start, but acts like its running on 3. When I engage the pto or go up a hill, it backfires and dies. What is your best guess. I think my next step will be to replace the plug wires. Any help will be appreciated. Gary
Claus
05-17-1999 09:23:53
 Re: 9N Misses and No Power in reply to Gary Perkins, 05-17-1999 03:47:06
I assume that it ran ok after the 12 volt conversion, so we can eliminate any problems with that. Maybe it is running on 3. Disconnect all of the plug wires from the spark plugs and reconnect them loosely. Start the engine,amd disconnect with an insulated pair of pliers one wire at a time and note the rpm. Reconnect and go to the next one. there should be a corresponding drop in rpm when you disconnect one cylinder at a time. If you get to a cylinder and notice no change, then you have found the problem cylinder. Let's go from there.
Happy Motoring
Claus
Claus
05-17-1999 09:30:44
 Re: Re: 9N Misses and No Power in reply to Claus, 05-17-1999 09:23:53
A word of caution. By insulated pliers I mean the use of heavy rubber gloves and or equivalent. The high voltage is to be respected. It will not kill you, (If you are a healthy person) but could give you a nasty jolt. Do not work on the distributor end for obvious reasons (Fan)
Be safe
(I do not want to get demerits from the safety council Mr. BG)
Happy Motoring
Claus
Wait a minute...bg
05-17-1999 09:34:18
 Re: Re: Re: 9N Misses and No Power in reply to Claus, 05-17-1999 09:30:44
I haven't received your Safety Council dues payment(cash or money order, no checks)yet.
Claus
05-17-1999 09:20:40
I assume that it ran ok after the 12 volt conversion, so we can eliminate any problems with that. Maybe it is running on 3. Disconnect all of the plug wires from the spark plugs and reconnect them loosely. Start the engine,amd disconnect with an insulated pair of pliers on wire at a time and note the rpm. (By ear) there should be a corresponding drop in rpm when you disconnect one cylinder at a time. If you get to a cylinder and notice no change, then you have found the problem cylinder. Let's go from there.
Happy Motoring
Claus
