Hello JH, If your headlights are sealed beam (#4019) at 5 amps each and If you have a rear sealed beam (#4019) light at 5 amps and If your generator is the original 11 amp three brush, then I suggest a standard/universal/three terminal/with integral fuse/three position light switch that is made for Off/Park/Head. Connect the headlights to the "Park" position. Connect the rear light to the "Head" position. This will let the generator carry the 10 amps of headlights without discharging the battery - if you have the generator control set to "High.". When using the rear light, the battery will have to make up the difference. If you use the rear light more than the front lights, reverse the hookup that I suggested above. Don't leave the generator set to "High" all the time. It will evaporate the water in your battery. Three to five amps for normal battery charge maintenance is sufficient. If your lights are not bright, you might add a #12 ground wire from the headlight terminals (for sealed beams) or the headlight shells (for bulb lights) back to the battery ground. Two corroded hood pivot bolts and five rusty instrument panel bolts do NOT make a good ground return for 10 amps. Hope this helps. Elvy
