Order Ford 8N Parts Online
More 8N throttle and rpm questions
Chipper
07-15-2007 19:40:00
I just purchased an 8N this weekend, first one, that runs and cranks great. However, the throttle seems to be very temperamentle. Seems like you have to move the throttle more than you should to see an increase in rpms. Then you really have to be watching because it will try to keep going and not stop where you have the throttle set at. It's usable but I know it's not supposed to operate that way. Could this be a case of worn out linkage? Any ideas?
Dell (WA)
07-15-2007 19:49:55
 Re: More 8N throttle and rpm questions in reply to Chipper, 07-15-2007 19:40:00
third party image
Chipper..... ...you may need to inspect yer throttle linkage for "slop".
But most likely, its yer "governor". Yer governor balls gitt flatt spotted and the cone race they roll on gitts grooved. Both can be repaired. To check yer governor, with engine running about 1/4th-throttle, grab yer carb to governor rod (it won't bite you) and try and "jazz" yer engine for more RPM's. Does it "fight you"??? NO? bad governor. Rebuild kit $100 (cheap) Replacement governor $250; yer call..... ....Dell
Chipper
07-15-2007 19:59:49
 Re: More 8N throttle and rpm questions in reply to Dell (WA), 07-15-2007 19:49:55
I know when giving it throttle and watching the arm on the carb where the rod comes in from the throttle does not move until you move the lever a considerable amount and then it'll jump. Also, unless the two arms where the governor are tied together, it will try to run away.
Dell (WA)
07-15-2007 20:28:26
 Re: More 8N throttle and rpm questions in reply to Chipper, 07-15-2007 19:59:49
Chipper..... ..I don't know how to make this more understandable. ITS YER GOVERNOR. rebuild it. Squander $25 for the I&T FO-4 manual. It even has pictures for the mechanically challenged..... .respectfully, Dell
Chipper
07-15-2007 21:11:03
 Re: More 8N throttle and rpm questions in reply to Dell (WA), 07-15-2007 20:28:26
Thanks for the info Dell.
