AMP Gauge
Mike in M.V.
05-16-1999 15:04:34
Have 47 2n all stock has amp gauge but does not appear to be hooked up Two nuts on back and a wire that runs through a loop type dohickey at the bottom of it.. wire is loose and does not appear to have ever been attached. If I touch wire
to the dohickey I get sparks but gauge does not move. Does anyony know how or where you hook up the amp gauge? The two nuts are the mounting bracket nuts
Po Folks
05-16-1999 15:25:27
 Re: AMP Gauge in reply to Mike in M.V., 05-16-1999 15:04:34
It is hooked up. But it needs tape to keep the bare wire from touching the ring. Should not be sparks.
Mike in M.V.
05-16-1999 15:33:05
 Re: Re: AMP Gauge in reply to Po Folks, 05-16-1999 15:25:27
I dont understand. should wire be touching and held solid to the ring? Or tape it so it does not touch the ring at all?
Mike In M.V.
05-16-1999 16:20:24
 Re: Re: Re: AMP Gauge in reply to Mike in M.V., 05-16-1999 15:33:05
Looking in the manual the wire that runs through the ring is a terminal block to starter relay. it is a continues running wire. should it be bare so it can make contact with the ring it passes through? And is this the wire that I should get a reading on my amp gauge with?
Robert
05-16-1999 19:12:04
 Re: Re: Re: Re: AMP Gauge in reply to Mike In M.V., 05-16-1999 16:20:24
The wire that runs through the ammeter is kinda like an antenna. The bare loop on the ammeter senses current flowing in the insulated wire (going to the battery terminal of the starter solinoid).
The wire should not be bare, if it is replace it. As I said the ammeter will sense current flow, the insulated wire passing through the ammeter acts like an antenna.
The ammeter on my 8N was reading backwards so I simply looped the wire the other direction and it works fine now.
Bob W
05-16-1999 17:49:29
The gauge works by induction, so the wire does just go thru the loop. It does need to be taped if it is bare. If it is not working try another gauge.
Kevin
05-16-1999 17:03:49
The wire should not be bare and it should not be attached to the ring. It should just pass through the loop. If you are not getting a reading on the gauge the gauge is bad. The only difference between your gauge and the replacement gauge (at least the Ford replacement) is you have to cut the wire and put loop connectors on each end and there are 2 terminals on the back of the new gauge.
