Order Ford 8N Parts Online
8n block interchange front mount/side mount dist
Jmck
07-13-2007 17:37:15
I"ve got a front mount distributor block thats no good and found a side mount distributor block, can I put my front mount distributor on the side mount block?
NO WAY!!!
07-14-2007 06:55:32
 Re: 8n block interchange front mount/side mount dist in reply to Jmck, 07-13-2007 17:37:15
A front mount dist. WILL NOT go on a side mount block!!!!! !! And no I don't care if the GREAT ZANE says "everything is the same", cause they AREN'T!!!!! !
Joe (IN)
07-14-2007 17:11:08
 Re: 8n block interchange front mount/side mount dist in reply to NO WAY!!!, 07-14-2007 06:55:32
I'm not sure who you are, but you knoweth not what you are talking about. You most certainly can install a sidemount block in place of a front mount. All the parts will bolt on and fit just fine. One of my 8N's came to me this way. Now it is, however, not possible to bolt a front mount block in place of a sidemount. Not without some serious modifications.
don b
07-14-2007 08:03:44
Yes you can put a front mount distributor on either block.The cam and front cover would have to changed tho.The only difference in the BLOCK is the oil fill hole is moved back a few inches on the block designed for a side mount dist.,like Zane says.There is some changes to the head also,but that won't effect anything if you are adding the front mount dist. to a side mount dist. engine block,only if you were going the other way. don b
JohnMD
07-14-2007 03:31:56
You can replace a front mount block with a side mount block. They all bolt up the same. I think this is what you mean. You of course will need a side mount distributor. A few other things are different. No ignition resistor, generator/regulator different, wiring different to name a few.
jmck
07-14-2007 09:13:14
 Re: 8n block interchange front mount/side mount dist in reply to JohnMD, 07-14-2007 03:31:56
I'll restate that question, I've got a 8n with a front mount distributor. The engine block has a large hole in it so after several phone calls I located just a bare block off a 8n but it had the side mount distributor. The question is, Can I take all the parts off my older front mount block and put them on the side mount and make it work?
ZANE
07-13-2007 17:51:50
Everything is the same except that the generator is on the left side on the side distributor engine block and the oil filter is back about 6 inches more than on the front distributor engine. All you would need is the generator bracket and maybe the generator if you can't use yours. Probably can because the late generator is mounted using a clamp on to the bracket.
Would have to come up with that left side generator bracket.
Zane
jmck
07-13-2007 17:56:30
 Re: 8n block interchange front mount/side mount dist in reply to ZANE, 07-13-2007 17:51:50
I've got a alternator mounted on the right side so It sound like I shouldnt have any problems.
Hobo,NC
07-14-2007 17:34:47
 Re: 8n block interchange front mount/side mount dist in reply to jmck, 07-13-2007 17:56:30
Do you plan to use your front mount head if so no problem if not the oil filter mounts in a different location on the side mount head. Worst case you can always mount you alt on the left side, If you think you may move the alt use a lower radiator hose for a side mount application. most gaskets set come with both timing cover gaskets or order the set for a front mount application.
