Order Ford 9N Parts Online
Friday 13th repair - 1939 9N aluminum shifter cover...
Dan
07-13-2007 15:29:56
third party image
third party image
Friday the 13th has always been a lucky day for me for some reason, so I dicided to take off work a little early and drop over to the local welding shop I found that specializes in welding aluminum. I showed the old guy the shifter cover, and told him what I needed to do, and he was truly amazed at the part. He said he has never seen cast aluminum that old, he didn't know they made it back in the 30th. Anyway, they hooked the ground to it, dropped the welders mask, I took a deep breath, and BOOM - within 5 minutes both holes were filled just as pretty as you please. They put a pipe on the inside to limit the slag I would have to grind down, but let it mound up on the outside. I was amazed that it was that easy. Took it home, hit the outside with an angle grinder, then finished it off with some hand files. Hand marked the new slot based on the CAD drawings of TOH and the pics from Randy (PA) from the board. I decideded to hand cut the straight lines with a hack saw blade, then make the radius at the bottom with the correct sized drill bit.I did start to wander on one side with the hack saw blade, but it came out ok. Overall, I can breath easier about the whole ordeal. Thanks to all the board members that helped me out on this one, it is truly appreciated.
Now - onto the steering...
Dan
James Rader
07-15-2007 18:24:37
 Re: Friday 13th repair - 1939 9N aluminum shifter cover... in reply to Dan, 07-13-2007 15:29:56
Beautiful, simply beautiful!
Dunk
07-13-2007 19:00:24
Dan, I may be wrong, but I am betting that the side away from the notch, even if it doesn"t supposed to have a hole all the way thru it, is at least is supposed to have a divot bored in it, to recieve the other end of the pin.
You should be able to tell when you get the shifter and pin back in, if it sticks out to far on the notch side.
But then I have been wrong before...
Upper Peninsula, MI.
07-13-2007 18:22:38
Dan, Very nice work. I have a 39, serial # 1500 with the same problem. Some one fixed it to work, but it won't last forever. What did your job cost and where did you get the cad plans? Ron
Dan
07-13-2007 18:37:30
 Re: Friday 13th repair - 1939 9N aluminum shifter cover... in reply to Upper Peninsula, MI., 07-13-2007 18:22:38
The repair cost me $25. Seems like a lot for the quick amount of time it took - but I was more than happy to pay it :-) Took me less than 30 minutes to grind down the slag with the angle grinder, hand file to shape, and cut the slot. I am pretty happy with the final outcome.
Send me an email, and I will reply with a pic of the CAD drawing that shows the dimensions of the slot.
Dan
gahorN
11-16-2007 14:09:35
 Re: Friday 13th repair - 1939 9N aluminum shifter cover... in reply to Dan, 07-13-2007 18:37:30
It ain't the TIME it took to do the job... It's the KNOWLEDGE and the SKILLs and the TOOLS that it took. It would have cost you more than several tractors to acquire all that capability for yourself.
$25 was a DARN GOOD DEAL! I wouldn't have been surprised to find it cost FOUR TIMES that much.
gahorN
11-16-2007 14:09:20
