Order Ford 8N Parts Online
8N sleeve removal
jerry
05-15-1999 21:05:55
Have a 1949 8N in need of overhaul. Pulled head
and a pretty good ridge in top of sleeve. Where
would one look for steel sleeve removal tool. Is it possible to remove sleeves with crank still
in place. Also where would find the driver to put
sleeves back. Any help appreciated. thx. JB
mel
05-17-1999 15:52:00
 Re: 8N sleeve removal in reply to jerry , 05-15-1999 21:05:55
Put sleeves in freezer. Turn engine sideways on the engine stand. prop up a reddy heater so that heat blows right though a cylinder. coat sleeves with light oil and the block should be almost too hot to touch like he just said. turn engine upright and take sleeves out of freezer one at a time and drop in.
Mike H(MD)
05-16-1999 07:27:59
JB
If they are thin wall sleeves start pushing the sleeve inward with a flat chisel or screw driver. then drive a screw driver between block and sleeve and break sleeve out( I used a old two fisted onewith the end rounded to keep from scoring block). To install put in freezer as Z-bar said but heat up block also (till you can barely put your hand against it)put a light coat of oil on sleeve and slide into block. If all things are right sleeve will slide in with just hand pressure only(will work with thick sleeves also removing those requires a puller)good luck...Mike
Z-BAR
05-16-1999 01:40:21
a sleeve puller can be bought at most auto parts stores. sleves can be removed with the crank in, but if renuing pistons and sleves just as well remove engine, check crank and add new bearings while your at it. the same puller can be used to install the sleves, i just put the sleves in the freezer for an hour they will hand push in all but the last 2 inches lay a 2x4 on top and rap with a hammer to seat. good luck.
