800 pistons/sleeves in 600 block.. can it be done??
Truck
02-05-2000 09:03:26
I have a real beat up 600 just begging for some engine work. I also have a freshly rebuilt 800 engine that was cracked from overheating.I'm trying to think of a way to combine the two and have a new improved extra powerful 172 CID engine in the 600. The 600 block is fine, and it looks like the difference in displacement was gotten by punching the bores out an extra 1/2 inch. While I know I have some slop in my piston to cylinder clearances, I don't think it is quite enough to stuff those Hi-perf pistons in there. Has anyone out there done this? Is it a case of boring the block for the 800 sleeves? Or isn't there enough material there for this? Is the head on the 600 and 800 the same? Inquiring minds want to know! ;O)
Thanks guys!
ZANE
02-05-2000 18:49:59
 Re: 800 pistons/sleeves in 600 block.. can it be done?? in reply to Truck, 02-05-2000 09:03:26
No! Not!
tOTG
02-05-2000 14:05:36
I'd get an oversize (.010, .020) kit for the 134 and have the sleeves re-bored. I pay $20 per hole, but $30 wouldn't be too much.
Yes, you can bore the 134 to accept 172 sleeves or run the pistons in the bare block. Bearings interchange; crank journals are same. 172 head uses larger stud bolts but I _think_ the chambers are the same.
If you don't have a 10" clutch, the extra HP will make it protest.
John.CO
