Wrong Link
Kim
06-17-2007 10:46:21
This link is fixed now... it was going to the old back up forums.
There is only one forum... with two optional views. The Classic view (which is the way they have always been, and will not change), and now we have the "Modern View" which uses the more modern interface similar to other forums on the net.
Classic View
Modern View
They share the exact same data, so regardless of what view you use to read or post, you are seeing the same information from both views.
We are still working out a few bugs... if you run across any you can report them in the Site comments forum or email Chris directly using support at ytmag.com
Just a reminder too, that the keyword here is "optional"! You can choose to view the forums however you wish, and you can even switch back and forth if you like certain qualities of both.
