Ah yes, soldering, a high tech solution to a low tech tractor (grin) I have several problems with soldering terminal lugs on N-tractors. 1) Solder creates a solid wire junction out of flexable multi-strand wire. N-tractors vibrate. Solid wires crack under vibration, flexable wires do not. Therefore, intermittant connection under all that liquid tape insulation or heat shrink insulation. All hidden from sight. All very difficult to "find". 2) If you don't use un-insulated terminal lugs to start with, your hot solder may melt the plastic insulation and wick it inside the hole and cause a cold solder joint with intermittants or high resistances (what you are trying to get away from in the first place) 3) Unless you use "radio solder" (rosin core), you will leave acid contaminates that will eat away the copper wire and cause intermittants and high resistances until it causes terminal failure. 4) Even if you do use rosin core solder, unless you "clean" the burned rosin flux away, it will oxidise and contaminate the solder joint and cause intermittants and high resistances until it causes terminal failure. My Boeing techs were forced into using "rubbing alchol" as first choice solvent for solder joint clean-up, learned new "french" words. "Freon" used to be the electronics industrys solvent of choice, until the gov't decided that all that A/C freon excaping from auto junk yards and such causes a great big ol' hole in the southern atmosphere that allows too much sunshine ultra-violet rays to deplete the Ozone layer. Bottom line, if you're having wiring problems on a N-tractor, a new wiring harness is not expensive or difficult to replace and will solve a lot of problems. Just my opinion..... ...Dell
