12V Coil Voltage
DDMi8N
06-08-2001 04:50:47
My 12V conversion is almost done. I am using a coil out of a 90s vintage Crysler. Their wiring shows no resistor in the coil circuit but I am thinking this function is taken care of in the electronic ignition module. Since I don't have electronic ignition (yet!), I figure I better have something in there to keep the points happy. What is the target coil voltage for a coil like this? I am guessing somewhere in the 8 to 9 volt range but don't really have a good feel for it . Thanks.
Dell (WA)
06-08-2001 10:11:31
 Re: 12V Coil Voltage in reply to DDMi8N, 06-08-2001 04:50:47
DD..... .Some 12volt ignition coils are really designed to run straight from the battery with NO resistors. Since multimeters are not too accurate at low ohms, measuring you primary winding probably wouldn't tell you too much, it should be in the 2.5 to 3.0 ohms range.
The real problem as you have identified is the ignition points. Point current is a factor of area of the point contacts. (small contacts do not carry large amps happily) If'n your really concerned, I'd measure the primary current, should be about 3 amps and no more than 5 amps max. ..... ....Dell
DDMi8N
06-08-2001 10:28:28
 Re: Re: 12V Coil Voltage in reply to Dell (WA), 06-08-2001 10:11:31
Thanks Dell. I will measure that current when I get her all hooked up and adjust it accordingly. The biggest problem right now is I can't find the damn battery. It is around the place somewhere...I just don't know where. Too much jet fuel fumes from flight test I guess. Thanks again.
