starter button
BrettD
04-15-2007 19:21:11
I have a 47 2N and I am having a irritating problem with that starter button right in front of the gear shifter. You have to push down really hard with your hand or use your foot to get the starter to engage. I know that the button pushes on a rod to engage the button in front of the steering assembly. I have even added pennies to make switch assy. require less force but to no evail. It will work with the greatest of ease for a little while but then go back being a pain in the but again. What is the problem?
bls
04-16-2007 18:30:17
 Re: starter button in reply to BrettD, 04-15-2007 19:21:11
I added 2 small flat washers to starter button shaft. You just have to remove switch. To get at the shaft and lever mechanism you have to remove hood, steering wheel, and sector gear upper housing. A lot of work to get at these parts! I would not tear into this just for this problem.
cjack
04-16-2007 10:19:55
Inflation has caught up to you. Use a nickel!
john hunt
04-16-2007 06:24:01
this simple answers those part that wore out ... replace these part, work great after you do it. put grease on rod, pin & lever so they move easyer. these are the part you need
1 switch 9n11450b 2 gasket 9n11506
3 lever 2n11515
4 pin 9n11511
5 button 9n11506 new batties cable too should work lot easyer as change my out a few year ago. what a pettey cheap fix,
Dell (WA)
04-15-2007 19:55:55
Brett..... ...ya know, you gotts all the parts in hand, and yer vision is better'n my long distance vision. Shirley, you can do an inspection better'n me for worn pivot joint in the jiggle-stick. ...or... you can make a longer jiggle-stick. ...OR... you can byte the bullett and buy a REPLACEMENT starter switch. p/n: 9N-11450-B (which is probably on its last legs) Really desperate shadetree mechanics have been known to diss-assemble the 2-terminal starter switch to find out the copper contacts are paper thin. wadda concept, replace worn parts..... ..respectfully, Dell
BrettD
04-15-2007 20:42:36
 Re: starter button in reply to Dell (WA), 04-15-2007 19:55:55
I already have a new starter switch installed right now. It has been on less than a month so that can't be the problem. The problem must be in the pivot joint or jiggly stick. How would get to this to replace either one of these parts.
don b
04-16-2007 09:28:43
 Re: starter button in reply to BrettD, 04-15-2007 20:42:36
Brett....you say....I already have a new starter switch installed right now. It has been on less than a month so that can't be the problem.
I say.....you could have got a bad swx.It depends on where you got it.I would check the swx. again. don b
BrettD
04-16-2007 10:16:12
 Re: starter button in reply to don b, 04-16-2007 09:28:43
The tractor cranks and starts up fine. The switches integrity is not in question. I am complaining about the button in front of the gear shifter which requires an extreme amount of force to manually engage starter button.(which is new and works just fine). In a previous post a man talked about the physical linkages running from the button to the switch. The only problem being I don"t see in my shop book on how to get to them.
don b
04-17-2007 08:20:19
 Re: starter button in reply to BrettD, 04-16-2007 10:16:12
Brett...the only way to get to the linkage is to remove the top half of the steering box. don b
