Order Ford 9N Parts Online
9N brake drum removal
Mike Roberts
06-06-2001 21:27:17
How do you get the brake drums off of this thing? My brakes dont work and I cant get to them.
Tyler (MD)
06-07-2001 03:35:19
 Re: 9N brake drum removal in reply to Mike Roberts , 06-06-2001 21:27:17
Chock opposite rear tire, jack up other side and remove wheel and block up axle trumpet. I remove fender for easy access. Remove 6 hex nuts on brake backing plate. The axle, and brake assy. come out as one complete assy. Loosen brake adjuster screw and backing plate and brake assy will come out of drum.
third party image
A neat trick is to bolt the brake assy back on the axle trumpet using a couple of 7/16" bolts and nuts. Now you're ready to take your shoes and socks off. :-)
third party image
Tyman
Mike Roberts
06-07-2001 17:56:07
 Re: Re: 9N brake drum removal in reply to Tyler (MD), 06-07-2001 03:35:19
Thanks so much for the info and pictures. Now I can get to work..... Thanks Mike Roberts
Dale O'9n
06-07-2001 04:31:37
Hey Tyman, Thanks for all the posts with pics. You have been a real help to me trying to get my 9n in order. I'm sure others appreciate it also. Dale in VA.
Mikey
06-06-2001 22:56:41
Mike,
Five nuts on the inside by the adjuster. Whole unit w/ axle slides out. Remember to loosen adjusters all the way to seperate drum after you get the whole thing on the bench.
Search the archives for a tutorial, LOTS of good info there.
Mikey
