Order Ford 8N Parts Online
Battery connected backwards (8n)
Bopsgeech
06-03-2001 22:58:31
The house I grew up in must have been full of lead paint and shrunk my brain. I feel like a DUMBELL.I've written for help here in the last month and a half about starting problems and today had a repeat of won't start, no spark. Before buying a new coil, I started checking wiring diagrams (I am really new to tractor mechanics) and realized I have been operating my 8n on reversed battery polarity! I think I am SLOWLY GETTING IT, but would any kind soul offer a rundown on "start here and check..." to help me discover what I may have damaged in my electrical system before I start replacing parts? Coil and distributor in front. Thanks to all who offer help. What a great web site!
bj/8N/mt
06-04-2001 07:37:03
 Re: battery connected backwards (8n) in reply to Bopsgeech, 06-03-2001 22:58:31
Can I assume that your 8N is still six volt stock?
If so it does want to be positive ground.
If that is correct the only polarity sensitive items are the voltage regulator and the coil. If the thing runs the coil likely survived. I would have to look myself at an I T FO4 manual to see how to polarize the generator but that needs to be done. If you don't have an FO 4 as Dell says--cheap at $25.00 getchaone.
If the machine has been dinked with--twelve volt wise disregard the above and consult an excorcist.
Your mileage may vary
Mountainman
06-04-2001 12:42:38
 Re: Re: battery connected backwards (8n) in reply to bj/8N/mt, 06-04-2001 07:37:03
While the coil is polarity sensitive, it is not harmed by reversing the polarity. All 12 volt conversions (that use an alternator) are negative ground and the front mount coil works fine (both 6 and 12 volt coils).
The FO-4 Manual is highly recomended. I also find the 1939 - 1953 Parts Catalog to be a valuable resourse.
Hope this helps.
Mountainman (CA)
Richard Fazio
06-04-2001 06:22:56
I just fixed up my neigbors 8N that had the battery in backwards. They had lent the tractor to someone who promised to fix the charging. When I looked at it the voltage regulator was hooked up wrong also. The only thing that got burnt was the regulator. The generator and everything else was fine. The battery was also dead. We got a new battery and voltage regulator, hooked it up correctly and all is fine.
Mountainman
06-04-2001 01:22:42
Only polarity sensitive components would be harmed. This might include the generator, battery and certainly the regulator. Unless it got hot or had other problems the wiring and starter should be fine. The coil and distributor should also be fine.
Hope this helps.
N � joy.
MOuntainman (CA)
DANMAN
06-04-2001 05:31:32
 Re: Re: battery connected backwards (8n) in reply to Mountainman , 06-04-2001 01:22:42
So is the 8n POSITIVE or Negative Ground?
jimp co.
06-04-2001 08:34:35
 Re: Re: Re: battery connected backwards (8n) in reply to DANMAN, 06-04-2001 05:31:32
POSITIVE Ground
TimK
06-04-2001 14:04:44
 Re: Re: Re: Re: battery connected backwards (8n) in reply to jimp co., 06-04-2001 08:34:35
8N = 6v. = postive ground. If you run it negative ground, you loose some of the spark thru the coil, since the coil is set for a postive ground system. Don't ask me the technicals as to why, but it's so and has been talked about on this Board before, I think Dell (WA). My $.02
