Order Ford 9N Parts Online
9n resistor
Tony
02-03-2000 15:36:07
I'm having trouble with my 9n It misses when I put it under a load and if I don't put the clutch in it will stall. So I did the tune up plugs, pionts,& condenser no change. If I bypass the resistor it will run good, so I put a new resistor and there was on change. What does the resistor really do? What harm will I do if I don't use one. Thanks for any help
Claus
02-03-2000 15:58:54
 Re: 9n resistor in reply to Tony , 02-03-2000 15:36:07
The main purpose of the resistor is to prolong point life... The coil is designed with this in mind. You may cook the coil if you bypass the resistor for too long. If you get better performance with the resistor bypassed, then I would suspect that you have an electrical problem somewhere.. You need a voltmeter to find the cause... Check on the coil with the points closed and you should read around 3 - 4 volts. One pesky problem is that with age, the ignition switch contacts get dirty and consequently have too much resistance.... bypass the switch with a jumper and see if this may cure your problem..
Happy Motoring
Claus
twopop
02-03-2000 17:46:44
 Re: Re: 9n resistor in reply to Claus, 02-03-2000 15:58:54
HAS THE COIL EVER BEEN CHANGED MAYBE YOU HAVE A COIL WITH A BUILT IN RESISTOR AND AN EXTERIOR REISTOR WOULD CUT YOUR 6V TO MUCH
built in resuistor - no such thing
02-03-2000 21:51:27
 Re: Re: Re: 9n resistor in reply to twopop, 02-03-2000 17:46:44
There is NO SUCH THING as an ignition coil with a built in resistor,
Elvy
Yes there sure is...
02-04-2000 03:56:32
 Re: Re: Re: Re: 9n resistor in reply to built in resuistor - no such thing, 02-03-2000 21:51:27
This is a subject that comes up every now and then. However, the burden of proof is upon those who say it is, and not upon those who say it is not. So without further adoo. There have been several manufacturers throughout the years who installed resistors inside the coil... Motors Auto Repair Manual for the year 1973 Lists the American Motors year 1967 6 cyl coil information on page 2-533 as an coil with an internal resistor. The coil has a primary resistance of 3.3-4.1 ohms at 75 deg F. The internal ignition resistor has a value of 1.3 to 1.4 ohms.. I can list others...
Happy Motoring
Claus
Elvy
02-04-2000 22:25:38
 Re: Re: Re: Re: Re: 9n resistor in reply to Yes there sure is..., 02-04-2000 03:56:32
Nash/American Motors? Built in resistor? A better idea?
Maybe that's why we don't see them any more.
Sorry Claus. Couldn't resist.
Elvy
Claus
02-05-2000 10:15:19
 Re: Re: Re: Re: Re: Re: 9n resistor in reply to Elvy, 02-04-2000 22:25:38
Ok... Elvi.. I never claimed that it was a good idea. As a matter of fact, I think it is a crummy idea...We sure do not need that additional heat in the coil....
If you think of it..... there were a lot of crummy ideas throughout history...
Happy Motoring
Claus
But we are talking Ns here!
02-04-2000 04:26:27
Ever been an N coil with internal resistor?? Didn't think so!
Claus
02-04-2000 05:56:01
 Re: Re: Re: Re: Re: Re: 9n resistor in reply to But we are talking Ns here!, 02-04-2000 04:26:27
I am not too sure about that.. I have a suspicion that they do have an internal resistor. I would like to hear a well though out argument as why you think that they do not. First, the total coil primary resistance needs to be in the 2 to 3 ohm range in a 6 volt coil, otherwise the points would self destruct when the ignition is on and the points are closed. The coil may also buid up too much heat. Now then, the first shooting from the hip answer would be that all one would have to do is increase the number of primary turns...What would that do to the reactance of the primary? An automotive ignition coil is a bunch of conflicting engineering principals. The coil needs to not destruct at DC and the core needs to saturate at both idle and higher rpm...Making a choke out of the primary does not meet the higher RPM need. The "N" does not have unique ignition system. Why would automotive manufacturers always have an ignition resistor in the primary of the coil if it were not needed... Ah... but I need more voltage when I start the engine, and this is one way of getting it by bypassing the resistor or having a thermistor in the primary with a lower voltage coil. If this is a valid argument for the rest of the world, then why is it not valid for the "M" Again, I do not claim that the "N" coil that does not need an external resistor does have an internal one. I only suspect that it does. Lucas and Bosh found out that by placing the resistor inside the coil was not a better idea...due to heat... Heat can be our enemy....when it comes ot engines..
Happy Motoring
Claus
John Regan
02-04-2000 17:46:54
 Re: Re: Re: Re: Re: Re: Re: 9n resistor in reply to Claus, 02-04-2000 05:56:01
Why do most coils have an external ballast resistance? To reduce the total current in the coil primary to only what is necessary. This obviously is to cut down on heat in the coil thus prolonging its life and also increasing point life. But why not put it in the coil with increased winding resistance? To increase the primary coil resistance you need to either have more turns or use finer wire. Finer wire would not carry the needed current. So why not use more turns in the primary? Because you would need even more turns in the secondary (high voltage side). The coil is in fact a transformer and it is the turns ratio (primary to secondary) that determines the output voltage (not totally but plays the major role). Thus more primary turns means more secondary turns. The secondary winding is already made from very very fine wire since there are thousands of turns in the secondary and doubling the primary turns would mean doubling the secondary turns. This fine wire breaks easily and generally speaking, getting the coil hot and cold during normal use causes thermal expansion and contraction which can stress the fine wire and break it. This heat can also cause the insulation to crack and fail allowing the coil to arc internally. The entire coil unit shares the heat so heating the primary also heats and expands the secondary even though the design physically attempts to reduce this. Thus you have conflicting design goals. You need high current and small number of turns in primary to keep the number of turns in the secondary within reason. Adding the resistance necessary to limit the primary current is best done outside the coil since it also thus moves the heat outside the coil too and helps prolong the life of the coil by reducing its temperature excursions.
Hope I did not get too tekeee.
Claus
02-04-2000 18:41:34
 Re: Re: Re: Re: Re: Re: Re: Re: 9n resistor in reply to John Regan, 02-04-2000 17:46:54
Yes you are absolutely correct. The turns ratio cannot be reduced since it would also reduce the spark current. Spark current approximately equals primary coil current devided by coil turns ratio, where turns ratio is the number of secondary turns devided by the number of prinary turns. Happy Motoring
Claus
John Regan
02-04-2000 17:44:47
