Order Ford 8N Parts Online
8N short circuit
Dave Luce
05-30-2001 19:32:23
The battery on my 8N keeps going dead. I think there is a short somewhere. I believe it is either the generator or the voltage regulator. Does anyone have some good ideas on how I can check them out? I live in a remote area of Alaska... Thanks in advance for any help!! Dave
8NRay
05-30-2001 20:55:07
 Re: 8N short circuit in reply to Dave Luce, 05-30-2001 19:32:23
You could always disconnect one battery cable post. That way there isn't any drain on the battery when not in use. Take a look at the wiring schematic and begin disconnecting wires and watch the ampmeter. When you disconect the thing that is drawing current with the switch off, you can then figure out what is wrong. Start with the voltage regulator then the generator.
Which remote area of AK are you in?
Dave Luce
05-31-2001 20:24:40
 Re: Re: 8N short circuit in reply to 8NRay, 05-30-2001 20:55:07
Ray: I am located about 40 air miles northwest of Anchorage across the cook inlet. I'm on the Yentna River , about 10 miles up from the mouth of the Yentna. It's about 25 miles to the nearest dirt road. I have a schematic, thanks to the "web" and checked things out I thought , using a fluke multimeter. Disconnecting the negative lead sounds like a real good way to go. I'll try it first thing tomorrow. Thanks so much!! Dave
