3 Point Hydraulics
James Franks
05-29-2001 20:58:43
Just got a 51 8N. Got it and Bush Hog for $475.00. There are a few problems but the most distinct one is with the lift. When I hook up the hog and raise the lift it will only lift the hog about a foot off the ground, however when I take the hog off it will work as normal. The dipstick shows the fluid to be about halfway between the bottom of the stick and the full mark when the hog is about one foot off the ground. Is this low? I was not sure if it reads the same as the one for the engine. Any help will be greatly appreciated thanks. James Franks
bg
05-29-2001 22:23:17
 Re: 3 Point Hydraulics in reply to James Franks, 05-29-2001 20:58:43
I'll give you your money back on it right now. There could be any number of problems, none of which should be too serious, unless the pump is worn out. More likely an adjustment problem, either in ther linkage or quadrant. The piston/cylinder could need attention. If you remove the round plate on the right side and inspect the innards while the lift is operating, you may discover fluid from above or turbulence below. You can also move the long tapered control arm and see if that changes anything. That will get you started. Get an I&T FO-4 manual for troubleshooting and repair procedures.
