Anyone know how to drill holes?
Tyler (MD)
05-27-2001 18:13:21
dave#1 needs your help.
third party image
He's got some 4' holes to drill with his 12" PTO pole digger. He's run into some tough clay and it takes him all day to drill a hole.
I suggested pouring some Coors Light down the hole and maybe it will loosen up the clay.
LOL,
Tyman
DaBrow
05-27-2001 21:24:08
 Re: Anyone know how to drill holes? in reply to Tyler (MD), 05-27-2001 18:13:21
I would suggest using "recycled" Coors Lite. Might as well use it twice. Conservation & all, right? ...DaBrow
Dumb Logger
05-28-2001 06:34:42
 Re: Re: Anyone know how to drill holes? in reply to DaBrow, 05-27-2001 21:24:08
Hey DaBrow, how ya comin' along on them leathers for N-tractor riders?DAVE#1 would probably want coors light written on his, down one leg, in yellow letters.
DaBrow
05-28-2001 08:03:11
 Re: Re: Re: Anyone know how to drill holes? in reply to Dumb Logger, 05-28-2001 06:34:42
....yellow down one leg. Just taking notes.
Dumb Logger
05-28-2001 10:12:48
 Re: Re: Re: Re: Anyone know how to drill holes? in reply to DaBrow, 05-28-2001 08:03:11
Well while you're takin' orders, I'd kinda like the red and grey 8-n colors with my puter handle monogrammed on the belt. Adjustable waist of course, sometimes I go N-ing after eating. Keep up the good work.
dave#1
05-27-2001 19:56:24
This "Clay" that I have here is like no clay you ever seen,the augar is new and has now drilled a total of 20 some holes in the last 2-3 years. I had trouble drill'n this "Clay" from day one, the cutting "Bits" are'nt worn down but do get "Dull", What I have been doing is to remove the cutting "bits" every other hole and sharpening them with my grinder, this seems to work but the drilling is still going slow.
Oh well, life goes on.(-:
later,dave
Ed Gooding (VA)
05-28-2001 05:29:09
 Re: Re: Anyone know how to drill holes? in reply to dave#1, 05-27-2001 19:56:24
Wow! Sounds like that stuff is about as hard as your new junior senator's heart!!
LOL..... ..Ed
'52 8N475798
and now you know........bg
05-27-2001 21:49:01
third party image
...the rest of the story.
Dumb Logger
05-28-2001 06:27:26
 Re: Re: Re: Anyone know how to drill holes? in reply to and now you know........bg, 05-27-2001 21:49:01
Is that pipe headed for the kitchen or the bathroom?
Now you've done it!
05-28-2001 05:55:52
Another classic that is bound to keep showing up here. I love it! Great work Bob.
ROFL
Alan
dave#1
05-28-2001 06:02:33
 Re: Re: Re: Re: Anyone know how to drill holes? in reply to Now you've done it!, 05-28-2001 05:55:52
later"belch"dave
swavo
05-27-2001 19:39:31
I wish we had some tough clay here in New England,we have petrofied potatos better known as rocks.If your holes don't have to be perfectly spaced one could use that unit, but if your hole must be at a certain spot you would be better off with a backhoe or an escavator to move the huge rock resting just below the surface.
mike
Charles (Mo)
05-27-2001 19:03:04
Ed probably is right. I dig holes every day to set electric poles for the coop where I work and I know that new teeth make a big difference. The digger I use is called a Star digger or production digger, your choice. It is a Ford deisel powered digger-derrick mounted on the bed of a 96' Ford F series. The truck weighs a little over 24000 lbs. and I can lift the trucks rear end off the ground with the auger. Even with that kind of pressure it is tough digging in hard-pan. But with new teeth... Also new teeth keeps the shank plates from wearing out.
Have fun.
Ed Gooding (VA)
05-27-2001 18:24:03
Dave, do you have replaceable cutters on your auger? I was having similar problems a couple of years ago. The cutters had worn down gradually and I hadn't noticed how much, until I bought a new set. Made a world of difference in getting down in this Virginia red clay.
good luck with it..... ...Ed
'52 8N475798
