Order Ford 8N Parts Online
8N Indecision Part II
KBob
05-27-2001 11:35:51
First of all thanks to those who contributed to my last message. ;)
I really gave it a thourough looking at as follows;
(only problems are added)
Front left steering ball joint shot
leaks oil slightly out of the oil pump(Which I hope is the gadget on the front right of the block sticking out)
and when you shake the rear wheels , you get a slight clunking noise
Finally, my biggest worry, when you depress the clutch you hear a disturbing medium sound of scraping .Its allmost a higher pitch sound than when the clutch is released.is this normal?
oh yea and a leak on the right rear hub seal>
thanks for all your help
Kenny
Mountainman
05-27-2001 19:42:45
 Re: 8N Indecision Part II in reply to KBob, 05-27-2001 11:35:51
Another possibility for the scraping noise is the pedal rubing on the floor board.
The leaking governor is easy to remove to replace the gasket.
The clunking sound could be a hub or axle � potentially expensive � check it closely.
Hope this helps - good luck.
Mountainman (CA)
smokie
05-27-2001 12:59:58
the clutch noise is most likly the throw out bearing the cluncking could just be an ajustment .
roperboy
05-27-2001 11:49:28
the ball joint is cheap to fix. the oil leak sounds like it is from the governor. don't know what to tell you about clunking noise or the scraping noise. there are some very knowlegable folks on this board who might know what that is. good luck
