6 cylinder id
Jerry (IN)
05-25-2001 06:19:54
Gentlemen, I've read previous post about funk 6 cylinder conversions. I have an early 48 8N with a flathead 6 conversion-nowhere can I find a funk id cast but it looks exactly like the funk on J. Smiths website. on the hood extension is a hole for a temp gauge the gauge is missing and there is a wire that runs from a temp sensor in the block, also has the channel iron beams, the engine has an id plate "ford industrial engine *7HNN*1002* and 46549*G25G" the numbers cast into the block are 1HA 6015 B, what size engine is this? a 226 cid 95 hp perhaps?
Thanks,
Jerry
Dumb Logger
05-25-2001 17:46:31
 Re: 6 cylinder id in reply to Jerry (IN), 05-25-2001 06:19:54
Jerry, I agree with what Dave said, mine has the #1HA6015A. We looked it up in a bearing book and it said it was a 226cid, it also said you could put 254cid sleeves in there in case 95 h.p. isn't enough for you.
My Funk is just like yours,an early model I guess.
D. R. White
05-25-2001 13:18:02
Jerry, It sounds like you have an early FUNK conv. Early kits came with channel iron beams instead of the cast oil pan. Not sure if the early kits had any Funk ID castings, mabe on the starter extension. Block casting should read 7HA-6015-B this would make it a 226 ci. 95 h/p motor. Hope this helps. Dave.
