8 N 3 Pt
Matt
05-24-2001 12:19:20
My 3 pt hitch does not lift very high and is pretty slow, I also hear a slight knocking noise while the hitch is lifting. The lower arms go almost to the ground when I lower the hitch without an implement on the hitch.
Could it be that the arms have been removed and then put back on the tractor in the wrong positions...on the splined shafts.
Thanks for any input.
Matt
bg
05-24-2001 17:47:19
 Re: 8 N 3 Pt in reply to Matt, 05-24-2001 12:19:20
There is a matched double spline on the shaft and arms, so it should only go back one way, unless someone has "modified" it somehow. I'd look to a worn cam follower pin and linkage/quadrant adjustment for the cause of the problem, along with a safety valve and control valve problem.
Jay
05-24-2001 16:34:02
Hi Matt, You can access this info at the top of the page under archive's.Just type in ZANE Hydraulic lift,he his the Expert on hyd. Although there are alot of very wise fellow's on this sight,and they are very helpful!Hope this help's.Your friend,Jay
