Order Ford 9N Parts Online
9N Carb Adjusting
Gary
02-01-2000 21:21:37
Hi all you all. This forum is GREAT...Especially for someone like me who is a brand new 9N owner.
Thanks A LOT...I rebuilt my carb last weekend and I set up the initial settings per the manual. The tractor starts ok and seems to run ok as well. I was able to push snow. However it seems to idle too fast. I turn down the idle adjustment screw and it seem to want to die out when I put it in gear. Does anyone know any tips or tricks to adjust the Carb correctly? Thanks again....Gar
David Edwards
01-27-2001 14:49:21
 Re: 9N Carb Adjusting in reply to Gary, 02-01-2000 21:21:37
carb and float adjust.
STUMP PULLER
02-02-2000 16:46:29
 Re: Re: 9N Carb Adjusting in reply to Nolan, 02-02-2000 05:09:29
MY N IS OLD TOO AND THE IDLE IS SLOW, BUT I NOTICE WHEN YOU PUT THAT N IN GEAR, AND IF THE IDLE LOADS DOWN THE GOVERNOR KICKS RIGHT IN AND KEEPS THINGS GOING. THAT IS THE NICEST THING ABOUT AN N. MAYBE YOUR GOVERNOR NEEDS HELP.
