Order Ford 8N Parts Online
50' 8N Hydrolics
Dan
05-23-2001 09:54:34
My neighbor has a 50' 8n that she wants to sell for $1400. It has 4 implements and looks like it's in pretty good shape. It fires right up and sound strong. The problem is the hydrolics need some work. They barely lift up the discs, and then when they are in the up position, as soon as you put it in gear and let out the clutch, they drop back down. They also bleed down as soon as you turn off the engine. Her husband passed away 5 years ago and it hasn't been used much since. He also had wired the small lever on the right side, in front of the big lifting lever, (don't know the name), in the down position. If you don't hold the little lever down hard, the implement drops down. If anyone has any suggestions on whether it would be worth buying and/or what it would take to fix I would very much appreciate it. Just the tractors in my area are selling for $2500. Thanks.
Dan
Dell (WA)
05-23-2001 10:22:01
 Re: 50' 8N Hydrolics in reply to Dan, 05-23-2001 09:54:34
Dan..... ..are you going to wear a bandana over your face when you hand that thar' widder woman $1400? (grin)
Hydraulic's overhaul about $250, $500 max.
Most used tractor implements $250 ea. (depending)
Let your conscience be your guide, I hope you'll beable to sleep at night..... ..Dell
to add to Dell's comments....
05-23-2001 13:53:06
 Re: Re: 50' 8N Hydrolics in reply to Dell (WA), 05-23-2001 10:22:01
You could say you'll buy it for the $1400. THEN give her at least $2K...a little more if you can afford it! She'll be estatic! You'll get a rush unlike any other you can expearence from her reaction. I speak from an expearence I had once when I was in college. Gave a tip WAY more than you'd expect to the girl that brought us root beers at the drive-in. Still can remember the reaction!! :-)
And you still have a bargan!!
As Dr. Laura says, "GO DO THE RIGHT THING!"
Regards,
Larry 8N75381
Danny in CO
05-23-2001 10:02:11
Try moving that lever to the vertical (up) position and try it again. From your description, that lever is the position/draft control lever. In the horizontal position, the hydraulics are in draft mode. In the vertical position, the hydraulics are in position control mode. Search for "position control" and you can fidn out the differences.
Danny
Jhill
05-23-2001 10:16:36
 Re: Re: 50' 8N Hydrolics in reply to Danny in CO, 05-23-2001 10:02:11
There is a discussion a few linesbelow on position/draft control
