2N Brake (backing plate)
Lincoln
05-23-2001 08:47:37
What is the secret to removing the backing plate from the axel/hub assembly. Does the brake arm have a collar with a pin ? Does this have to be removed to remove plate? Have try but have had no sucsess in removing the plate, do not want to damage it. Thanks for any help.
Dell (WA)
05-23-2001 10:29:59
 Re: 2N Brake (backing plate) in reply to Lincoln, 05-23-2001 08:47:37
Link..... I believe the procedure is well described in the I&T FO-4 manual, you do have one don't you? $25 cheep, gettcha one..... .Dell
Maybe this link will help
05-23-2001 15:10:33
 Re: Re: 2N Brake (backing plate) in reply to Dell (WA), 05-23-2001 10:29:59
Link below.
Tyman
TimK
05-23-2001 14:45:07
I agree w/ Dell, get yourself a manual. That backing plate if it hasn't been off in awhile is stuck. There is nothing holding it. You just have to work with it and be careful not to chip the drum on the edge when you start prying like I know you are going to have to do. Use lots of liquid wrench. It'll come. My $.02
Lincoln
05-23-2001 21:47:52
 Re: Re: Re: 2N Brake (backing plate) in reply to TimK, 05-23-2001 14:45:07
Thanks for all the advise.
