Any fan shrouds in use?
Dennis 9N/2N
05-22-2001 21:13:52
Noticed discussion on the 21st about fans. How about fan shrouds? My 1946 parts book lists a fan shroud for 1943 through 45, although my 9N/2N doesn't have one. Does anyone have a fan shroud on a tractor with front mount distributor, and if so, how do you remove the distributor to work on it?
Dennis
Old George
05-23-2001 04:56:14
 Re: any fan shrouds in use? in reply to Dennis 9N/2N, 05-22-2001 21:13:52
Dennis, this 45 has a shroud, and it does not interfere at all with front mount removal or replacement.
Alan Esch
45 2n kit 183513
Paul8n
05-23-2001 03:44:47
I have one on my front dist. 8n. Paul
Tyler (MD)
05-23-2001 03:04:04
Dennis,
I think many fellers will tell ya you don't need the shroud. I have a 9N without the shroud. Before I restored it, it was used on the farm without the shroud. If the cooling system is in good shape, it shouldn't get hot enough to need one. Of course I have a more modern 8N type that's pressurized.
JMHO,
Tyman
rasputen
05-22-2001 21:53:31
I had a fan shroud when I took the hood off last fall "to replace the radiator".(OK,... I am still doing a valve job") The shroud was sorta' missing at the ends, so it was possible to get the FM dist. off. I think I will think about an After market replacement, and I now have a Thermostat!!!"Henry" needs to keep his cool.
When I would lug him down he would spew a bit from the rad and go on.
