2n with funk conv. info ?
Tim
05-22-2001 11:13:09
I have a 2n with a 6 cyl. and would like to know where to find info on this engine. Such as what the points should be set at. Thanks
tlak
05-22-2001 16:33:41
 Re: 2n with funk conv. info ? in reply to Tim, 05-22-2001 11:13:09
Tune up spects says .015 for all the Ns and a flathead site says .016 for the 8s so you should be in the ballpark with these. Most other fords .024-.026.
Dave Smith Another great site
05-22-2001 16:47:27
 Re: Re: 2n with funk conv. info ? in reply to tlak , 05-22-2001 16:33:41
I don't know how I missed that one.
Dave Smith <*)))><
Dell (WA)
05-22-2001 16:07:09
Tim..... ..found this down at the bottom of this page of the N-Board. Hope it helps..... .Dell
When getting parts, just say that the engine is out of a 1948 to 1951 Ford truck with the 226 ci engine. The kit most likely uses an industrial engine, but the parts will be the same as a Ford truck. There may be some differences in parts such as the carb and water pump within those years, but if you search within those years you will find the parts you need. The only engine parts you won't find are the starter drive and armature, which are unique to the kit.
For tune-up specs, just get a book which covers those years of Ford trucks.
Dell is right......But......
05-22-2001 18:08:16
 Re: Re: 2n with funk conv. info ? in reply to Dell (WA), 05-22-2001 16:07:09
if you what some numbers to get you going before you get a manual there are some. Points .024-.026 Plugs .025-.028 Firing order 1,5,3,6,2,4. H-Series engine. Casting number on side of block should read 7HA-6010-B. It,s a 226 cu.in. 95 HP @ 3300 RPM. Timming TDC @ 200 RPM. Hope this helps. Dave.
Paul8n
05-22-2001 12:32:35
You could do search under funk, hope this helps, Paul
