318 John Deere with ONAN engine very expensive to rebuild
John N
05-21-2001 21:24:24
Rather off the subject from my 48 8N, but I just recently retired my old 214 JD with a 318 JD. I took a chance and purchsed this mower and the machine looks real good with a almost excellent 50 inch deck and had all the features that I was wanting like power steering, hydrostat and a pressurized oiling system with a filter.
It ran very well and did not knock or smoke I THOUGHT, after about 15 minutes you almost couldn't see the machine because of the oil smoke. Well I decided to tear into it and found worn rings and somewhat worn pistons. I have always been told that the Onan engines were suppose to be long lasting engine this one had 711 hours on it. I also found out that the previous owner was not very faithful on preventive maintence, explains the need of an major overhaul.
Well this is my first and probably my last Onan made engine they are very very expensive to rebuild. Pistons .010" over were $114.00 a piece and .010 under rods were 55 bucks a piece. Am I just a fool and have sucker all over my face or is Onan proud of their parts?
Oh by the way my local John Deere dealer was the cheapest on the parts I called everyone who uses the Onan engines in their products. Now here my 52 year old 8N just keeps going and going, should have just put a belly mower on the underneath of it and been done with it, lol.
All said and done the final price for the John Deere 318 with complelty rebiult engine and all machine work I will have about $2300 in it. I guess that's not too bad but sure was dissapointed in that Onan engine.
John
Red
06-28-2004 06:24:28
 Re: 318 John Deere with ONAN engine very expensive in reply to John N, 05-21-2001 21:24:24
Can you tell me anything about a JD#60Skidsteer. This is a very small machine with a tiny forward bucket. One fellow told me they were very underpowered.Thanks Red
Steve
06-26-2002 10:10:12
 Re: 318 John Deere with ONAN engine very expensive to rebuild in reply to John N, 05-21-2001 21:24:24
Do you have any diagrams or other info that would help me with rebuilding my 318 onan? Would very much appretiate any help at all. Thanks Steve
wrenchman
05-23-2001 02:19:34
ran into the same problem on a skidsteer loader i bought.priced onan parts,they wanted more than i gave for the whole loader(probably why it was cheap).picked up a used 23hp kohler from a fried welder for $5oo.and used it instead.was an easy swap and works good.
Musicman
05-22-2001 07:15:36
It must be in the maintenance. I have the same JD 318 with almost 600 hours, no smoke, no oil added between yearly oil changes. It is a very strong tractor and in my neck of the woods will sell for about $3000. Mine has never had any work but routine maintenance. Good luck with the rebuild.
bj/8N./mt
05-22-2001 05:24:17
My experience with Onan parts is the same as yours. They are just really proud of their parts.
When I put cast in the pan of the wife's QT 16 Bolens it turned out to be a lot cheaper to get a whole new P220 20 horse Onan than the parts alone for a rebuild on the old 16 horse. On the other hand she now has the fastest mower in the valley.
Your mileage may vary
Ultradog MN
05-22-2001 03:59:29
711 hours doesn't sound right to me. I've had a Miller welder with an Onan on it for about 20 years now. Bought it new. I'll bet it has 3 or 4 times that many hours on it. It still starts and runs well and I've never done a thing to it save points, plugs and an oil change on occasion.
Meanwhile, hope you get it fixed before the grass gets too high.
