Order Ford 9N Parts Online
Backhoe attachment on 9N.
Minnesota Fats
05-17-2001 08:34:44
I am in the process of installing a small hoe on My 9n and have some concerns.
Should you use the 3 point to lift the backhoe off the ground? Or should the backhoe be stationary? How much weight can a N carry on its 3 point? I have a loader with front pump, 4 gallon hydraulic resevoir, and heavy duty Home made grill/hydraulic mounting system up front.
Do you think that is enough weight to offset a 750 lb hoe? Also do you think that a 4 gallon hydraulic resevoir is large enough to run a small hoe?
Larry 8N75381
05-17-2001 11:35:09
 Re: Backhoe attachment on 9N. in reply to Minnesota Fats, 05-17-2001 08:34:44
MF,
Who made your back hoe? It SHOULD have some sort of safety hitch that keeps the hoe from lifting the tph lift arms when you put down the outriggers. The safety hitch keeps the hoe from crunching the operator between the hoe and the tractor seat/steering wheel. OUCH!!!
Therefore, becasue of the safety hicth, the WHOLE hoe (at least my Woods 750 does) is supported by the top link rocker of the tractor. The lift arms just hang there since they cannot lift against the safety frame. If you tried to lift the hoe witht eh control lever (once the hoe is attached) you would just lift the relief valve in the hydraulics. The only thing the lift arms do is give left/right stability. The whole hoe is a LOT of load/abuse to put on the cast iron rocker. I broke mine on my Ford 3000. :-( I would worry about one on an N, though yours may be light enough to be OK.
Mounting the hoe is a trick that you will have to master. I finally built a frame to set the hoe on when it is off the tractor. I made the frame so I could slip three scissor jacks under it, two on each side and one at the back. Then I can raise up the hoe to line the top link up holes so I can put the pin in. I then mark the height at each jack so I can match the same lift to remove the hoe. Still have to "help" the pin out with a drift and hammer because it never quite matches up.
I'll have to get some picts up on photopoint of the frame. The pict of the hoe on the trailer had the hoe setting on the frame, but it is a distance shot so you cannot see the frame too well. Meanwhile check out the other photos I have posted at URL below.
Regards,
Larry
Minnesota Fats
05-17-2001 12:25:43
 Re: Re: Backhoe attachment on 9N. in reply to Larry 8N75381, 05-17-2001 11:35:09
Hey, Neat photo's, wish you had a couple of the mounting system though. After seeing your tractor with hoe in action I am a little worried.
My hoe looks about the same size as yours only heavier. It is an International Harvester 3082 series A. I would post a picture but I dont get the optional Image URL thing. Anyway thanks for responding.
Errin OH
05-17-2001 09:56:32
Minnesota, I have a fixed BKH on a 53 NAA, so not sure about the 3pt question. But would speculate that since I can lift my arms up when in the lowered position (not sure if this is normal or not), you would either have to tie them down or use the BKH when they are raised. ????? Concerning the hydraulic question. I have a 5 gallon tank as run around 3-4 gal with no problems. The question I have is, does your loader use one way (power up, gravity down) cylinders or is it 2-way (power up, power down). One way cylinders do not beeld any fluid back into the resevoir, thus reducing the level as you raise the loader. This shouldn't be to big a problem, I doubt that you will be trying to use them at the same time. But if they pull to much from the resevoir you could get air in the lines (feeding the BKH) and cause some eradic operation of the BKH. With reguards to the loader, My loader was to much for the front end. I mean there was no way to turn the front wheels when not moving (empty loader). After mounting the BKH she's evened out pretty good. Little light up front when empty, Little heavy when loaded. But managable. Just watch it, you will feel the differance. Last but by no means least, "Be Carefull" addinng the accessories changes the way the tractor operates. Center of gravity, front to back ratios, etc... You my want to consider a ROPS (Roll Over Protection system)
