Distributor Confusion
Zeusdog
08-02-2006 07:38:54
It's been since the early 70's that I've messed with condensor and points. Killed way too many brain cells since then. I got a tuneup kit from the site here and when I pulled the distributor off, a small piece of copper fell out. I've looked in the manual and the picture seems to show a connection from the condensor mount to the breaker arm spring. Is this what I am missing? I have absolutely no juice to the plugs but I do have fire to the end of the coil. I tried to do a search before bothering the board with what is probably a dumb question, but with 21000 possible articles...
Any help will be greatly appreciated.
BillM (OH)
08-02-2006 13:57:19
 Re: Distributor Confusion in reply to Zeusdog, 08-02-2006 07:38:54
Ya gotta have that copper strip in place, but it doesn't have to be anything fancy. I cut a hunk off a sheet of copper I keep in the shop for making furniture nameplates for my 8N, and I soldered a hunk of #12 to the back of the strip that broke on my 861. Both have worked fine for years.
RoNofohio
08-02-2006 12:05:29
When the copper strip on mine broke several years ago, I took a short piece of #12 copper wire, fashioned it to fit and then beat it flat with a hammer so it resembled the copper strip that broke. It's been on about 10 years now. It works so well, I just stopped looking for a replacement.HTH..Ron
Zeusdog
08-02-2006 08:39:12
Thanks for the replies. It is a front mount on a 49 8n. I'll see if I can fabricate another copper strip to connect the condensor mount to the points mount. I assume it simply mounts to the same screw as the points spring.
Thanks again.
Bob
08-02-2006 08:37:12
The copper strip from the points terminal to the condensor terminal MUST be intact, or you won't have spark.
SOME QUALITY breaker point sets have a copper strip that parallels the steel spring, and if you have an old set like that, you can make a replacement strip from the one on the points.
A length of 14-GA insulated stranded copper wire with a couple of eyelet terninals will serve the same purpose, until you can get a proper replacement, if you so desire.
SCgoatfarmer
08-02-2006 08:19:30
Replaced the condesor and points about 2 months ago on my 49 front mount distirbutor.
If it is a front mount, there is a very thin strip of copper "tape" stretching from where the top of the points mount to where the condensor contact is screwed down (where the 4 nipple round can copper spring connects).
If this thin metal strip is missing (very delicate and could easily be torn off) then I wouldnt think you are going to get any juice to the spark plugs.
Still learning as I go and this might not help at all.
Empennage
08-02-2006 08:10:46
Make sue??
I meant, "make sure" the screw that holds the points gap is secure. Sheash..have another cup of coffee Emp..
8N'r
08-02-2006 08:23:06
 Re: Distributor Confusion in reply to Empennage, 08-02-2006 08:10:46
Emp--it sounded like the beginning of a nice rhyme! LOL --Another hidden talent?
"make sue the screw is secue"
Empennage
08-02-2006 08:25:25
 Re: Distributor Confusion in reply to 8N'r, 08-02-2006 08:23:06
Geez it's frick'en hot out. I am sure my brain is fried!
Empennage
08-02-2006 08:10:42
Make sue??
Empennage
08-02-2006 08:02:41
Is this a side mount distributor? If it is that strip of copper goes from the inside ring(on the post) of the distributor ( wire comes down from the round can coil to the outside of the dist) to the points. Then the condensor has a "U" shaped clip that goes on the same post on the points. Make sue the screw that holds the points is tight
