Order Ford 8N Parts Online
8N 12 volt system
James Franks
05-14-2001 20:17:17
Hey guys I have another question. How do I tell if the 51 8N I just bought has a 12 volt system or not? These tractors came new with 6 volt systems didn't they? It has what appears to be an alternater. Again I assume they came new with a generator as opposed to an alternater. The "alternater" has Delco Remy on the back of it and is mounted on the left side of the tractor. I just want to make sure I buy the right battery don't need a melt down if you know what I mean. Any help is appreciated. Thanks. James Franks.
Dell (WA)
05-15-2001 01:04:57
 Re: 8N 12 volt system in reply to James Franks, 05-14-2001 20:17:17
James..... ...99.99% certain silver colored Delco Remey object is a 12 volt alternator. Which means you need a 12 volt battery that is negative grounded.
I'm amaized that you bought a tractor without a battery to start it up to at least listen to the engine and operate the hydraulics and drive it around in circles to see if the gearbox and clutch work. Good Luck
Respectfully..... .Dell
knucklehead
05-14-2001 20:52:52
You could put a volt meter between the 2 battery post or count how many cells or caps the battery has 3 its a 6 / 6 its a 12
