Order Ford 8N Parts Online
8n Head Gasket
Doug Lewis
05-14-2001 19:08:37
Do you put any thing on the gasket and bolt threads when installing a new head gasket? Thanks Doug Lewis Esopus NY
Nogrimace
05-15-2001 04:48:14
 Re: 8n Head Gasket in reply to Doug Lewis, 05-14-2001 19:08:37
Normaly you do not put any type of gasket sealer on the head gasket. I do beleive that their is a sealer built into the gasket and when it gets hot it helps seal it. Just remember to re-torque the head bolts after you run it awhile. I've never put any type sealer on the bolt threads, like lock tight. Good luck.
TimK
05-15-2001 06:39:25
 Re: Re: 8n Head Gasket in reply to Nogrimace, 05-15-2001 04:48:14
No head gasket sealer, but put permatex on the head bolt threads to help prevent coolant leaks. my $.02
