Order Ford 8N Parts Online
8N Sputters????
CJ
05-13-2001 12:53:41
After about an 1/2 hour of use my 8N starts to sputter. I just tuned it up. Any ideas???
Thanks
CJ
Steve B
05-15-2001 10:40:15
 Re: 8N Sputters???? in reply to CJ, 05-13-2001 12:53:41
If you have the model with the front-mount distributor, you may have dirt & dust built up inside the cap and on the points. I've had 8N's for over twenty years and this seems to be aroutine occurence. Hope this helps.
bj/8N/mt
05-14-2001 07:03:23
If it runs good cold and takes half an hour to develope the trouble likely suspects are electrical. In no particular order coil, condensor, ignition switch, point gap are all places to look.
Less likely is a partial obstruction in fuel flow. Three screens in system [over engineered?] any one of which would be obstructed.
One Ford book says a loose fan belt can contribute to overheating which boils gas in the tank--believe that or not, your call. Start witht the simple stuff and work up to the escoteric.
Your mileage may vary
SMOKIE
05-13-2001 13:44:52
CHECK YOUR FUIL FLOW ONE THING I HAVE LERNED FROM THIS BOURD IS ALL YOUR N NEEDS IS SPARKIES GAS AND AIR .
SMOKIE
05-13-2001 13:51:54
 Re: Re: 8N Sputters???? in reply to SMOKIE, 05-13-2001 13:44:52
THEN AGAIN IT COULD BE YOUR COIL BRAKIN DOWN WHEN IT GETS HOT GOOD LUCK
