Order Ford 8N Parts Online
8N won't start in cold temps????
Scott
01-31-2000 10:36:28
I have a '51 8N with a six-volt system which recently began giving me trouble starting in cold weather. The battery's brand new and checks out fine. (I also remove the battery and keep it inside to keep it warm during cold weather.)
It seems that when the temperature rises well above 30F, it'll start right up, but below that, it'll kick over and sputter, but won't run. I have cleaned the carb, the sediment bowl, and the fuel line. Could it be just a case of old plugs, or should I be looking for something more complicated? Thanks!!
Dan
02-02-2000 17:32:55
 Re: 8N won't start in cold temps???? in reply to Scott, 01-31-2000 10:36:28
Had same problem. Did new plugs, cleaned the carb out, etc. - still sputtered. New plug wires finally fixed it for me.
Joe Hamel
01-31-2000 16:15:39
Scott,
When did you change your plugs and points? Start by changing your plugs.
You might consider going to a 12 volt system. You can purchase a kit for under $200. I live in Mi. My 1950 with 6V would not start in sub zero weather. The 12V system started this Saturday when it was -12.
Joe
Joe
dave(47 8n)
01-31-2000 15:47:53
Make sure your pto is out of gear when starting(less drag), also the kind of engine oil you use will affect starting, the thicker the oil, the harder to start(I use 10W30)..install Autolite 437's(I think this is the number).. they are a nice hot plug for the N..also make sure your battery cables are in good condition with clean tight connections...
Dave
Bill T. (Cent. IL)
01-31-2000 13:37:40
I had the same thing happen recently, and new plugs fixed the problem. In fact, now, even without charging the battery at all, I can get it to turn over at 10 deg. or thereabouts. It's a $5 fix that won't hurt.
Good Luck,
Bill T.
Dennis N Tx.
01-31-2000 11:39:01
You might have some water in the gas and it is freezing in the fuel line or in the carburator, causing this problem.
My 2 cents...
Dennis
8N48II82
