Alternator Pulley
WVDave
05-09-2001 16:35:35
I have a 12V Alternator, The pulley has a narrow groove. (I brought it this way ). Where can I find a Pulley with a wide groove? So I stop damaging my belt.
DICK/MASS.
05-09-2001 18:33:15
 Re: Alternator Pulley in reply to WVDave, 05-09-2001 16:35:35
Go to parts suppliers site (link in upper left corner of this page) then go to Genesee Products. I got a brand new one from him. Worked out great
Bus Driver
05-09-2001 17:49:46
Grainger sells the Browning line of cast iron pulleys. The fixed-bore hub series can be bored in a lathe to the diameter of your alternator shaft- probably 17 mm. Makes the smoothest running pulley imaginable. For belts 1/2 wide, use 2 /14 or larger pulley. I made the mistake of using pulley too small diameter for the belt width and the heat from the belt flexing around the tiny pulley ruins the belt in a hurry.
SMOKIE
05-09-2001 17:14:29
YOU CAN PICK ONE UP AT MOST AUTO GENERATOR SHOPS BUT I JUST PUT THE ONE OFF MY GEN. IN THE DRILL PRESS AND DRILLED THE HOLE TO FIT.
