3 point hitch
Tim B
05-07-2001 14:51:48
I am replacing my 3 point hitch on my 9N but I need to replace the studs and seals, that hold the lower arms to the tractor housing. Can someone please tell me the part number or the name? When I try and remove the lower arms the stud just turns.
Chris Finkbeiner
05-07-2001 19:07:54
 Re: 3 point hitch in reply to Tim B, 05-07-2001 14:51:48
The studs that you refer to are the lower link support shafts. They are held in place with a castellated nut on the inside of axle housing. You will have to remove the axle trumpets to get at these nuts :( I believe these nuts are torqued to 150 ft/lbs. Good luck!
