Amp meter wiring
ED
05-06-2001 12:44:57
In an effort to isolate an electrical problem, I have been re-wiring my 1946 2N (6v pos grnd) piece by piece.
I looked at re-doing the amp meter wires, when much to my surprize, it seems as though the wire simply passes through the back of the meter continuously. How does one remove and reconnect the wiring to the amp meter. Currently it has the original cloth insulated and badly frayed wire.
Steve W
05-07-2001 09:36:27
 Re: amp meter wiring in reply to ED, 05-06-2001 12:44:57
That 16 dollar wiring harness was over budget?
Take Care
Steve
ED
05-07-2001 12:35:57
 Re: Re: amp meter wiring in reply to Steve W, 05-07-2001 09:36:27
very funny steve - was trying to avoid that level of work. One of these days, I will replace the whole thing.
And I will be sure to tell you all about it.
Salmoneye
05-06-2001 13:42:39
If the issue is that you want to replace the original wire with new wire, but keep the original ammeter, simply cut the old wire, remove it and attach a new wire at one end where the old wire was connected. Then pass the new wire through the loops on the back of the old ammeter in the same direction as the old wire, and connect the other end where the second end of the old wire was connected...done...
The Original Ammeter registers amperage through inductance in the loops on the back. The wire itself never makes contact with the meter...
Claus
05-06-2001 13:33:35
Cut the wire, put lugs on them and connect to the ammeter...If the charge direction is wrong, then reverse the wires.
Happy Motoring
Claus
