Order Ford 9N Parts Online
9N problems......
Keith
05-06-2001 12:05:54
I have recently purchased a 1941 9N at a local farm auction. Drove it the two miles home, after about a week of "light" work, it began to sputter and stall. Did full tune-up at this point including plugs, rotor, cap, coil, and condenser. Has been running fine for about two weeks until today. Started its sputtering and stalling again, however, I am able to stop that by holding the choke completly open. Where should I check for this problem?? This is my first "N" tractor.
hey Keith when it gets warm and sputters
05-06-2001 17:00:15
 Re: 9N problems...... in reply to Keith, 05-06-2001 12:05:54
check for a vacccuum leak at the manifold and follow the advice below. all of them guys are right on the money. When it starts to sputter rev it up to full throttle and listen to it. if it is uneven it is starving for fuel or air or both
R.M. in AL.
05-06-2001 13:34:24
I had the same problem with a 9n I owned. Most likely its in your fuel tank, bowl screen, or somthing starving the engine for fuel. Take the line loose at the carb. and let it drain a while to see if it starts to slow down any.It should be a steady stream of fuel, about like an old man peeing.Hope this helps.
Mountainman
05-06-2001 13:29:24
Several possibilities. It sounds to me like a fuel problem so I will start there.
1. A vaccuum leak at the manifold or carb
2. There are three fuel filters. One in elbow of carb inlet, one above glass bowl (get a new gasket), and one inside the fuel tank (unscrew the shutof/bowl assembly, but drain fuel tank first)
3. Clean out/rebuild the carb.
Check your fuel flow. Is it a steady stream or just a little dribble?
Since you just got the tractor you might want to check inside the gas tank. I found enough hay to keep a horse happy in mine (along with assorted berries and nuts).
Also check to see if the gas tank's vent is plugged. Next time it starts to sputter loosen the gas cap, if that solves the problem your vent is probably plugged. You have to remove the hood and gas tank to clear the vent.
Hope this helps.
Mountainman (CA)
