3 point question
Gary (NY)
01-30-2000 13:58:38
I have a question concerning my lift arms. I have a York 5 ft backblade on my '46 2N and when I raise it sometimes it pulsates when it reaches the up position. If I If I move the lever towards the down position it stops pulsating. It does it when the tractor is warmed up. What could be the cause of this? Thanx
bg
01-30-2000 20:19:05
 Re: 3 point question in reply to Gary (NY), 01-30-2000 13:58:38
If quadrant adjustment won't fix it, you probably need to inspect the internal components for wear. Could have worn or sticking control valves that are contributing, also.
Gaylord(Pa)
01-30-2000 17:33:09
Hi Gary, When my'45 2n did that,it also drifted
up and down.All I did was order and install
a Zane Thang and my hydraulic works fine.I couldn't begin to brush-hog because of the
drifting and chattering.Now it's easy.
I hope this helps. Gaylord(Pa)
Charlie in TX
01-30-2000 17:28:45
I am by no means an expert but I think you need to adjust the quadrant(touch control) lever. It is covered in the IT manual If you have one. Perhaps Zane will come along with a better answer.
