Order Ford 9N Parts Online
9N Hyd
JRH-TX-9N
05-04-2001 07:11:33
Zane & Dell,
Thanks for the info. Here�s what I forgot to tell earlier. Have replaced the safety valve; see no leakage from the ram cylinder with pump running, just a little swirling around the pump. When I disassembled the pump, found one of the valve sets sticking on the guide pin. Also, is the control valve pressed in & does anyone have a picture of this valve? Still need to replace all gaskets. Thanks again! James
ZANE
05-05-2001 04:56:50
 Re: 9N Hyd in reply to JRH-TX-9N, 05-04-2001 07:11:33
The control valve bushing is pressed in. The control valve must move freely.
The fact that one of the springs in one of the pumps was faulty does not prevent the pump from pumping. Each of these four pumps is completely isloated from the others and three will still lift any weight that four will only slower and jumpy.
