Order Ford 8N Parts Online
8n position control
Jon P in NC
01-30-2000 09:20:22
third party image
I have been using my 8n at work the last couple of day moving snow. One thing I have noticed is the position control does not work very well. It seems to just be all up or all down but not much middle positioning. Yes the lever under the seat is in the proper position. I am going to check some of the adjustments later today (using the I&T manual) but I need to know what might be wrong. What part of the quadrant should control the positioning?
Thanks
Jon E. Purut
ZANE
01-30-2000 18:41:24
 Re: 8n position control in reply to Jon P in NC, 01-30-2000 09:20:22
It sounds like the notorious dreaded cam follower pin may be worn out or off.
Here is one of my old posts. Maybe it will give you clue.Now is definately the time to replace the cam follower pin. That much wear does make a lot of difference in how the lift works and when it starts to lift according to where the lift control is positioned.
I would defininately obain the correct part to replace it with.Don't go with a cut off bolt etc. as it will wear down too quick.If you are going to consider using a bolt etc you may as well leave the old pin in place because with it worn half way into it out last a bolt etc.
I shouldn't tell you this ,but I have used and ole valve stem by grinding off a piece of proper length.The repalcement is a hardened pin and it has to be hard to prevent rapid wear.Their is no lubrication to the pin. If you foolishly decide to use a valve stem it should be measured with a micrometer to assure the right diameter.If it is a couple of thousands too smalll it may fall out and if it is too large you will ruin the hole it goes in,then the right pin will fall out. Be sure and support the linkage as close to the pin hole as possible while driving the pin in or out.You can do this by holding a long heavy flat ended bar by the pin as it is driven out with a punch of correct diameter. Usually takes two people to do it. One to hammer and one to cuss. Added on Date: 05:50:33 2/14/99
bg
01-30-2000 10:16:33
Could be the quadrant adjustment but more likely a worn cam follower pin. The control arm inside might also be bent. It doesn't take much movement of the arm to activate the valve. I'd put my $$ on the cam pin.
Jon P in NC
01-30-2000 19:43:50
 Re: Re: 8n position control in reply to bg, 01-30-2000 10:16:33
Thanks guys. I pulled the right inspection cover off to see what I could see. Could not get a look at the cam follower pin but the control arm was interesting. Looks like it had been bent sometime in the past and a stiffing plate welded to it. The plate ran almost the whole length of the arm. What would cause this arm to bend? Should I replace it or not?
Thanks Again
Jon E. Purut
BB Stacker
01-31-2000 06:44:40
 Re: Re: Re: 8n position control in reply to Jon P in NC, 01-30-2000 19:43:50
Jon: Your control arm was probably purposely bent at some time. This seems to be a popular quick fix for worn or miss adjusted linkage. It looks like you will have to pull the cover to replace the cam follower and If it were me, I'd change the control arm. I have about the same situation (bent control arm) and it's impossible to make the adjustments by the book with this condition. The best I could do was get the draft control to work but the position control will not go all the way down. The Zane Thang may be the answer.
