Wow! Well, all your ideas are VERY helpful!!! OK, I am getting a picture of how to do this. And it's ok, Garageguy. :-) I appreciate your concern, but however new I am to mechanics, I'm not new to "the world of adventure." I do know the seriousness of the possibilities here. It's why I would never have taken on this project without the advice on this forum!! You guys give me a fighting chance. As it happens, the ranch/hardware store locally has only grade 2 bolts. So phooey! I am now calling around to see what I can find, as even those grade 2s are not long enough to attach the engine to the stand (if I wanted to use grade 2 for that, which I don't believe I do at this point). Soooo I will probably have to drive quite a ways to get bolts before I take the next step. The good news is this gives me time to plot my next steps of flywheel removal. Empannage, the engine is not as secure as I'd like, but it's supported at present by the jack adaptor frame, an additional jack, and the wood you saw. I plan to work that flywheel out of there with great care for that very reason, and Jo has said she'll help. But you've pointed to the Achilles heel of the whole thing. I'm hoping removing the weight of the flywheel will allow me to stabilize the engine WAY better so I can jack it up to get it onto the engine stand. But I may have to fool with it more on this end, first. It IS presently stable, however. I checked it again this morning. Old, you are right that I find myself in precisely the awkward position you predicted. But hey, at least it means I'm predicatable! LOL We just could not get that winch up over the rafter. We tried. I suppose the cherry-picker would have been good to rent, but I am really not sure we could have maneuvered it into the shop. And I also think the transmission jack adapter would have worked perfectly had the local mechanic not "adapted" it a little more than I think it was meant to be "adapted". I'm just glad I trusted my own instinct to ram the screwdriver through there! Whew! Dell, are you saying that all I have to do is keep one of the pistons from being able to come up in the cylinder, and this will keep the crankshaft from turning? If so -- COOL! Maybe I can do that and have fewer "things" stuck into the flywheel. It sounds like it will be bristling like a porcupine by the time I pry it loose! You all are the BEST! I've wanted to do this work all my life, and I'm going to make it because of you all! It might not be gracefully done, but this has already been one of the most wonderful experiences of lifetime -- and I've been lucky enough, blessed enough, to get to do a lot of cool stuff. THANK YOU again!!! Dawn
